delete cfm segment
delete cfm segment [segment_name | all]
Description
Deletes one or all CFM segments.
Syntax Description
segment_name An alpha-numeric string identifying the segment name.
all Specifies all CFM segments.
Default
N/A.
Usage Guidelines
Use this command to delete one or all CFM segments.
The following example deletes the CFM segment "segment-new":
delete cfm segment segment-new
This command was first available in ExtremeXOS 12.3.
Platform Availability
